> no start CEL Code 12 and constant flashing (misfire?), tried everything kind of stumped
post Jul 9, 2015 - 8:21 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
Hi all, een having a problem starting my car ever since I got the transmission replaced.
First, the car was giving me a
CEL 12 wiring and connector g2 + signal, STA signal crank position sensor and ECU
14 and 15 wiring connector, ignition coil, ecu
There is also another 14 code listed in the diagostic -wiring and connector, ignition and ecu
Things I've tried:
I've checked all plugs first to make sure there was no significant damage. (Found some on the main harness connector under the fuse box in the engine bay) checked for continuity, seemed fine.
Checked wire going from ECU to crank sensor for continuity, replaced crank sensor to no avail.
I also changed the cam sensor. Car still won't turn over.
We checked for spark and fuel (I'm getting spark and I'm getting fuel as my FPR is reading pressure and in took out injector plug #1 and used a NOID Light.
We also checked for spark and fuel using an old school method by bypassing injectors and putting fuel directly in. The car DID start but ran horribly and cut off shortly after.
Now I have a constant blinking when I pulled codes.
There was NO signal coming from ecu to injector according to Noid light. So it MUST BE ECU? Nope. Replaced ecu same no start but now I'm only getting code 12 and still getting a misfire code (constant blinking)
Does anyone have any helpful suggestions? A bud of mine and I will be tracing wires today but any assistance would be greatly appreciated.
Placham Thanks for the ECU and help so far. I'm sure we can figure this misery out!
- easternpiro1   no start CEL Code 12 and constant flashing (misfire?)   Jul 9, 2015 - 8:21 AM
- - easternpiro1   Did some more probing and continuity testing (spec...   Jul 9, 2015 - 7:19 PM
- - VavAlephVav   http://bgbonline.celicatech.com/ http://bgbonline...   Jul 9, 2015 - 11:41 PM
- - placham   Yeah no prob... hope u get it sorted,,, text me if...   Jul 9, 2015 - 11:56 PM
- - easternpiro1   Thans man! I just realized I didn't menti...   Jul 10, 2015 - 12:18 AM
- - VavAlephVav   ...ahh well if you've got it swapped that chan...   Jul 10, 2015 - 11:16 PM
- - Smaay   do continuity shoots between the sensor and the EC...   Jul 16, 2015 - 10:54 AM
- - easternpiro1   Thanks smaay! I did that and found that I go...   Jul 22, 2015 - 2:06 PM
|- - placham   so hows the car doing now, did u get her back runn...   Jul 28, 2015 - 3:31 AM
- - Smaay   oh, i just saw that you have a 4th gen in there. c...   Jul 28, 2015 - 9:06 AM
- - easternpiro1   Hey fellas! Thanks placham, car is not running...   Jul 29, 2015 - 2:18 PM
- - easternpiro1   Welp.... ALOT has happened since I last posted... ...   Mar 27, 2016 - 8:31 AM
- - Tigawoods   I think a photoshopped image of your car coming ou...   Mar 27, 2016 - 8:48 AM
- - presure2   So....since matt brought this back from the dead.....   Mar 27, 2016 - 9:49 AM
- - easternpiro1   Lol!! Thanks bruddah!!! A...   Mar 27, 2016 - 11:26 AM
- - Smaay   yep crank sensor.   Mar 27, 2016 - 11:51 AM
- - njccmd2002   so no more crying now, the car is fixed!   Mar 27, 2016 - 8:03 PM
- - easternpiro1   Lol yup! And will be for sale in a few months...   Mar 28, 2016 - 4:25 PM
- - njccmd2002   whattttttttt!   Mar 29, 2016 - 1:04 AM
- - easternpiro1   Yup! Lol time for a lex   Mar 29, 2016 - 12:32 PM
- - njccmd2002   Nooooooo   Mar 29, 2016 - 11:38 PM
- - easternpiro1   Lol I'm in no rush to sell. But its that time   Mar 30, 2016 - 3:08 PM
- - trdproven   PIRO - you forgot you OG too man...   Apr 12, 2016 - 1:52 AM
Lo-Fi Version Time is now: July 29th, 2026 - 4:16 AM
