Jul 9, 2015 - 8:21 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
Hi all, een having a problem starting my car ever since I got the transmission replaced.
First, the car was giving me a CEL 12 wiring and connector g2 + signal, STA signal crank position sensor and ECU 14 and 15 wiring connector, ignition coil, ecu There is also another 14 code listed in the diagostic -wiring and connector, ignition and ecu Things I've tried: I've checked all plugs first to make sure there was no significant damage. (Found some on the main harness connector under the fuse box in the engine bay) checked for continuity, seemed fine. Checked wire going from ECU to crank sensor for continuity, replaced crank sensor to no avail. I also changed the cam sensor. Car still won't turn over. We checked for spark and fuel (I'm getting spark and I'm getting fuel as my FPR is reading pressure and in took out injector plug #1 and used a NOID Light. We also checked for spark and fuel using an old school method by bypassing injectors and putting fuel directly in. The car DID start but ran horribly and cut off shortly after. Now I have a constant blinking when I pulled codes. There was NO signal coming from ecu to injector according to Noid light. So it MUST BE ECU? Nope. Replaced ecu same no start but now I'm only getting code 12 and still getting a misfire code (constant blinking) Does anyone have any helpful suggestions? A bud of mine and I will be tracing wires today but any assistance would be greatly appreciated. Placham Thanks for the ECU and help so far. I'm sure we can figure this misery out! -------------------- |
easternpiro1 no start CEL Code 12 and constant flashing (misfire?) Jul 9, 2015 - 8:21 AM
easternpiro1 Did some more probing and continuity testing (spec... Jul 9, 2015 - 7:19 PM
VavAlephVav http://bgbonline.celicatech.com/
http://bgbonline... Jul 9, 2015 - 11:41 PM
placham Yeah no prob... hope u get it sorted,,, text me if... Jul 9, 2015 - 11:56 PM
easternpiro1 Thans man! I just realized I didn't menti... Jul 10, 2015 - 12:18 AM
VavAlephVav ...ahh well if you've got it swapped that chan... Jul 10, 2015 - 11:16 PM
Smaay do continuity shoots between the sensor and the EC... Jul 16, 2015 - 10:54 AM
easternpiro1 Thanks smaay!
I did that and found that I go... Jul 22, 2015 - 2:06 PM
placham so hows the car doing now, did u get her back runn... Jul 28, 2015 - 3:31 AM
Smaay oh, i just saw that you have a 4th gen in there. c... Jul 28, 2015 - 9:06 AM
easternpiro1 Hey fellas! Thanks placham, car is not running... Jul 29, 2015 - 2:18 PM
easternpiro1 Welp.... ALOT has happened since I last posted... ... Mar 27, 2016 - 8:31 AM
Tigawoods I think a photoshopped image of your car coming ou... Mar 27, 2016 - 8:48 AM
presure2 So....since matt brought this back from the dead..... Mar 27, 2016 - 9:49 AM
easternpiro1 Lol!! Thanks bruddah!!!
A... Mar 27, 2016 - 11:26 AM
Smaay yep crank sensor. Mar 27, 2016 - 11:51 AM
njccmd2002 so no more crying now, the car is fixed! Mar 27, 2016 - 8:03 PM
easternpiro1 Lol yup! And will be for sale in a few months... Mar 28, 2016 - 4:25 PM
njccmd2002 whattttttttt! Mar 29, 2016 - 1:04 AM
easternpiro1 Yup! Lol time for a lex Mar 29, 2016 - 12:32 PM
njccmd2002 Nooooooo Mar 29, 2016 - 11:38 PM
easternpiro1 Lol I'm in no rush to sell. But its that time Mar 30, 2016 - 3:08 PM
trdproven PIRO - you forgot you OG too man... Apr 12, 2016 - 1:52 AM![]() ![]() |
| Lo-Fi Version | Time is now: September 15th, 2026 - 2:50 PM |
