Jan 7, 2017 - 4:42 PM
Enthusiast ![]() Joined Jun 11, '16 From lancashire Currently Offline Reputation: 0 (0%) |
Hi, I have noticed that my celica st205 has been going through a lot of oil, I think it was about 2 litres last week and it now appears to be back to the same low level it was before, basically for a while it has been dripping oil slightly, nothing serious about 5 drips a day however it has got a bit worse earlier today I did check the rocker cover bolts and they seemed lose however I did tighten them up a bit so hopefully this has solved the issue.
The main issue is that is now burning a lot of oil, I do notice that sometimes (but not all the time) dipstick gets pushed out ever so slightly so I thought it was rings but I would've thought that it would get pushed out after every drive? Sometimes on startup it doesn't smoke but then after idling for 20 seconds and it starts smoking a lot. My friend put his leg in front of it and later that night noticed later that night his pants were black and a bit wet so would've thought thats oil related. I took off the charge cooler and had a little sniff inside and it is hard to describe the smell but it did seem slightly sweet/oily and if I open the throttle body I can see at the back of the manifold looks a little bit wet so could that be turbo leaking a bit of oil into the air stream? I will be doing a compression check tomorrow to see how the rings are. |
rhodesyboy High oil consumption. Jan 7, 2017 - 4:42 PM
Bitter Is the turbo outlet area oily soaked? A leak down ... Jan 7, 2017 - 11:43 PM
rhodesyboy Straight after the turbo seemed to be ok the only ... Jan 8, 2017 - 8:27 AM
Smaay if you are blowing out the dipstick, you are press... Jan 9, 2017 - 12:21 AM
The_enD https://www.youtube.com/watch?v=M0ZfOKmcJLc Jan 9, 2017 - 4:35 AM
rhodesyboy True, I guess I need to wait for the leak down kit... Jan 9, 2017 - 6:53 AM
Wild202 There are several options:
1 oil scraper ring
2. T... Jan 13, 2017 - 2:27 AM
rhodesyboy Yeah oil scrapers are one of my worries, I would g... Jan 13, 2017 - 4:14 PM
Wild202 I would start with the replacement valve stem seal... Jan 14, 2017 - 12:47 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 24th, 2026 - 1:10 PM |
