> Rebuild SSS (Super Strut Suspension), SSS
post Jan 10, 2017 - 10:42 AM
Wild202
Joined Jan 10, '17
From Russia, Izhevsk
I brought to you how I solved the problem with a thud on the suspension arms SSS.
I really like to use it SSS suspension arms, because I had the opportunity to compare with McPherson suspension, because like last machine was ST-202.
But after the purchase, I discovered a terrible knock on all the front suspension, which has been difficult to locate.
I started to deal with this problem.
This post has been edited by Wild202: Apr 13, 2018 - 3:20 AM
Email - vad07@inbox.ru
- Wild202   Rebuild SSS (Super Strut Suspension)   Jan 10, 2017 - 10:42 AM
- - Rusty   This may help diagnose your problem... QUOTE F...   Jan 10, 2017 - 11:04 PM
- - Wild202   Thanks for your reply. I solved this problem. I wi...   Jan 10, 2017 - 11:27 PM
- - Wild202   Then, all saws and autopsied. We take out the insi...   Jan 11, 2017 - 9:09 AM
- - Wild202   More photos bushings who worked in arms: https://d...   Jan 12, 2017 - 12:08 AM
- - Wild202   handle fingers leverage hinges. Grinding, but not ...   Jan 12, 2017 - 6:14 AM
- - Wild202   Continue. Here are a few photos that would underst...   Jan 13, 2017 - 7:15 AM
- - Wild202   More photos manufacture bushings process. https://...   Jan 14, 2017 - 12:31 AM
- - Wild202   General view of the SSS control arms before the as...   Jan 15, 2017 - 2:04 AM
- - Wild202   Photos ready suspension arms SSS: Myself I levers ...   Jan 15, 2017 - 10:30 AM
- - The_enD   nice stuff   Jan 15, 2017 - 4:27 PM
|- - Wild202   QUOTE (The_enD @ Jan 15, 2017 - 5:27...   Jan 15, 2017 - 10:27 PM
- - slavie   That is a lot of work. Looks like you had to break...   Jan 15, 2017 - 9:56 PM
|- - Wild202   QUOTE (slavie @ Jan 15, 2017 - 10:56...   Jan 16, 2017 - 2:44 AM
- - Wild202   Here's another example embodiment. There are r...   Jan 16, 2017 - 10:33 PM
- - Wild202   Now, I do not change my suspension arms on the my ...   Jan 17, 2017 - 9:46 AM
- - Wild202   I apologize for my clumsy English. If anything is ...   Jan 18, 2017 - 1:28 AM
- - BonzaiCelica   http://www.gt4-racing.eu/index.php/toyota-...suspe...   Jan 18, 2017 - 3:21 PM
|- - Wild202   QUOTE (BonzaiCelica @ Jan 18, 2017 - 4...   Jan 18, 2017 - 11:05 PM
- - The_enD   Do you sell any of this? Or just for you?   Jan 19, 2017 - 3:29 AM
|- - Wild202   QUOTE (The_enD @ Jan 19, 2017 - 3:29...   Jan 19, 2017 - 3:46 AM
- - Wild202   I can explain why I decided to do it. The thing is...   Jan 21, 2017 - 12:28 AM
- - Wild202   I make the suspension arms are much cheaper and ca...   Jan 21, 2017 - 11:28 PM
|- - texasnick   QUOTE (Wild202 @ Jan 21, 2017 - 11:2...   Feb 9, 2017 - 3:39 PM
|- - Wild202   QUOTE (texasnick @ Feb 9, 2017 - 3:3...   Feb 10, 2017 - 12:34 PM
- - Wild202   So, yesterday finished Rebild next set SSS suspens...   Feb 12, 2017 - 6:04 AM
- - Wild202   So. Continued. Recently sent me mail the old lever...   Feb 17, 2017 - 12:41 AM
- - Wild202   The photo shows that the suspension arms have some...   Feb 17, 2017 - 10:13 AM
- - Wild202   Inner sleeve all the broken 100% Just throw them a...   Feb 18, 2017 - 12:19 AM
- - Wild202   We put new plugs. Like these ones: https://drive.g...   Feb 19, 2017 - 2:08 AM
- - enderswift   Good work dude   Feb 19, 2017 - 8:41 AM
|- - Wild202   QUOTE (enderswift @ Feb 19, 2017 - 9...   Feb 19, 2017 - 11:46 AM
- - Wild202   But that is not all. Then give your fingers in the...   Feb 19, 2017 - 12:07 PM
- - Wild202   The assembly, paint and suspension arms are ready ...   Feb 20, 2017 - 1:04 AM
- - BonzaiCelica   cool, your basically showing the whole process of ...   Feb 20, 2017 - 3:36 PM
|- - Wild202   QUOTE (BonzaiCelica @ Feb 20, 2017 - 4...   Feb 21, 2017 - 5:53 AM
- - Wild202   Thus, continued. I got another package, in which l...   Mar 6, 2017 - 10:57 AM
- - Wild202   Look further. What's inside? The photo shows t...   Mar 7, 2017 - 5:19 AM
- - Wild202   The bent and deformed fingers ball throw in the tr...   Mar 7, 2017 - 9:22 AM
- - Wild202   We collect everything, we paint. + Whole anthers o...   Mar 8, 2017 - 9:00 AM
- - Wild202   Soon several more reports will be about the rebuil...   Mar 17, 2017 - 9:14 AM
- - Wild202   So, the continuation. I was again sent suspension ...   Mar 18, 2017 - 12:46 PM
- - Wild202   In general, everything is as usual. The only mediu...   Mar 18, 2017 - 10:51 PM
- - Wild202   These same suspension levers are just finished + i...   Mar 20, 2017 - 7:12 AM
- - Mr_Tee   Great job man....How long does these expected to l...   Mar 20, 2017 - 9:59 AM
|- - Wild202   QUOTE (Mr_Tee @ Mar 20, 2017 - 9:59 ...   Mar 20, 2017 - 12:03 PM
- - Mr_Tee   Check PM   Mar 21, 2017 - 8:39 AM
|- - Wild202   QUOTE (Mr_Tee @ Mar 21, 2017 - 9:39 ...   Mar 21, 2017 - 12:00 PM
- - Wild202   I'll continue. Another regular set of suspensi...   Mar 28, 2017 - 10:33 PM
- - Wild202   Then we disassemble and see this: https://drive.go...   Mar 31, 2017 - 4:29 AM
- - Wild202   All the parts, which in the photo above had to be ...   Mar 31, 2017 - 4:35 AM
- - Wild202   Photo of ready-made SSS suspension arms (Now the s...   Apr 1, 2017 - 10:36 AM
- - Wild202   So, another set of old SSS levers came to me by ma...   Apr 19, 2017 - 11:26 PM
- - Wild202   We disassemble the suspension arms of the SSS: htt...   Apr 20, 2017 - 3:41 AM
- - bloodMoney   Incredible work! So for rebuilding a second t...   Apr 20, 2017 - 9:23 AM
- - Wild202   QUOTE (bloodMoney @ Apr 20, 2017 - 9...   Apr 20, 2017 - 12:29 PM
- - Wild202   So, everything is ready. https://drive.google.com/...   Apr 21, 2017 - 11:11 AM
- - bloodMoney   Amazing. You are doing the community a great ser...   Apr 21, 2017 - 2:32 PM
|- - Wild202   QUOTE (bloodMoney @ Apr 21, 2017 - 2...   Apr 22, 2017 - 11:29 PM
- - Bitter   This is inspirational work man, truly.   Apr 21, 2017 - 6:54 PM
- - BonzaiCelica   just to clarify, how much to rebuild all pieces? T...   Apr 25, 2017 - 4:11 AM
|- - Wild202   QUOTE (BonzaiCelica @ Apr 25, 2017 - 4...   Apr 25, 2017 - 12:05 PM
- - BonzaiCelica   hmm comes out to near same price as poland guy. he...   Apr 28, 2017 - 2:23 PM
|- - Wild202   QUOTE (BonzaiCelica @ Apr 28, 2017 - 2...   Apr 29, 2017 - 4:40 PM
- - BonzaiCelica   i just got the camber control links reburbished by...   Apr 30, 2017 - 7:07 PM
|- - Wild202   QUOTE (BonzaiCelica @ Apr 30, 2017 - 7...   May 1, 2017 - 3:42 AM
- - The_enD   Your friend here says you will have to ship back y...   May 1, 2017 - 3:52 AM
- - bloodMoney   ^This.   May 1, 2017 - 10:37 AM
- - BonzaiCelica   understood!   May 1, 2017 - 5:47 PM
- - Wild202   Yes everything is correct. Soon one more photo-re...   May 2, 2017 - 10:33 PM
- - Wild202   I apologize for the delay, a lot of work. I will c...   May 14, 2017 - 12:30 PM
- - Wild202   So, that's what they sent me this time: https:...   May 14, 2017 - 12:37 PM
- - Wild202   But now we look, that inside: https://drive.google...   May 14, 2017 - 12:41 PM
- - Wild202   That's all that is thrown into the garbage in ...   May 14, 2017 - 12:44 PM
- - Wild202   Tomorrow I will write a continuation Thanks to all   May 14, 2017 - 12:50 PM
- - Wild202   Since nothing can be done from these levers, the c...   May 16, 2017 - 4:28 AM
- - Wild202   So, the leash cases were selected in good conditio...   May 17, 2017 - 1:38 AM
- - BonzaiCelica   where were you 10 years ago?!!!   May 17, 2017 - 5:59 PM
|- - Wild202   QUOTE (BonzaiCelica @ May 17, 2017 - 5...   May 17, 2017 - 10:37 PM
- - BonzaiCelica   its a joke!!! when i heard about super...   May 19, 2017 - 11:55 AM
|- - Wild202   QUOTE (BonzaiCelica @ May 19, 2017 - 12...   May 19, 2017 - 1:37 PM
- - Wild202   Soon there will be a couple of reports.   May 22, 2017 - 9:59 AM
- - Wild202   Since I am engaged in the restoration of SSS lever...   May 25, 2017 - 3:43 AM
- - Wild202   So, that's what is inside the levers of the SS...   May 29, 2017 - 11:18 AM
- - Wild202   I forgot a bit about the photo. So, here is a phot...   Jun 19, 2017 - 11:38 PM
- - slavie   Good work! Do you have replacement boots for ...   Jun 20, 2017 - 9:53 AM
- - Wild202   Thank you. What "replacement boots"?   Jun 21, 2017 - 11:55 PM
|- - slavie   QUOTE (Wild202 @ Jun 21, 2017 - 11:5...   Jun 22, 2017 - 9:42 AM
- - Wild202   Got it. We call it anther. Which ones do you need?   Jun 23, 2017 - 1:29 AM
- - asdrewq   Fantastic work Wild202! This is a great servic...   Jul 12, 2017 - 1:57 PM
|- - Wild202   QUOTE (asdrewq @ Jul 12, 2017 - 2:57...   Jul 13, 2017 - 12:50 AM
- - Wild202   And yes, maybe you are right, and maybe not. I do ...   Jul 13, 2017 - 12:34 PM
- - Wild202   So. The next set of SSS suspension levers: https:/...   Jul 16, 2017 - 1:18 AM
- - Wild202   Another set of levers SSS: https://drive.google.co...   Jul 22, 2017 - 12:32 PM
- - Wild202   I forgot completely. I will continue. Dismantled e...   Sep 6, 2017 - 12:43 AM
- - Wild202   Ready-made SSS suspension arms for ST-205. https:/...   Sep 6, 2017 - 12:48 AM
- - BonzaiCelica   Would be nice off a company offered these arms in ...   Sep 6, 2017 - 11:36 PM
|- - Wild202   QUOTE (BonzaiCelica @ Sep 7, 2017 - 12...   Sep 9, 2017 - 12:06 PM
- - Wild202   Hello. The following set of suspension arms ST-205...   Oct 10, 2017 - 12:00 PM
- - Wild202   The same levers SSS suspension only already made. ...   Oct 19, 2017 - 9:21 AM
Lo-Fi Version Time is now: August 31st, 2026 - 8:37 AM
