Feb 11, 2017 - 1:53 PM
i have been busting my back trying to find a parasitic drain. i think i found what drains my battery.
i have 2 options. the aftermarket pioneer radio or the aftermarket alarm. funny. anyone has had an aftermarket radio do this. its a pioneer. i have both disconnected and seems too be no more drain. of course i have to see which one is the culprit.... stay tuned -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Feb 11, 2017 - 2:42 PM
If you have a good multimeter you can measure the amperage via it's fuse to see how much power the item itself is drawing, a good number for total parasitic draw is about 50ma on a car with a bunch of stuff like you have, it's probably the alarm though, especially if it's a fancier one. My 00 Celica has a steady 30ma draw when sitting off, it's got a factory alarm with features comparable to aftermarket alarms (intrusion, glass break sensor, keyless entry). The radio will have some key off draw to keep settings alive, but if it's got a high draw it could be the bluetooth module inside not going to sleep. I've seen that happen with Honda factory sound systems.
Feb 11, 2017 - 2:48 PM
the alarm is factory. which is odd.. the radio, is new, but you may be right...
Feb 11, 2017 - 4:06 PM
very odd, I'd put the money on the aftermarket stuff any day over OEM stuff but weird things happen. How high isn the total draw?
Feb 17, 2017 - 7:54 PM
not sure if the alarm was the full problem, i also had to replace batery under warranty. so we will have to see.
Feb 18, 2017 - 10:17 PM
Enthusiast ![]() ![]() Joined Jan 20, '08 From New York Currently Offline Reputation: 1 (100%) |
I had a parasitic drain issue caused by the factory alarm. Clamp on dc current meters are fairly cheap now and would be a good way to check current.
| Lo-Fi Version | Time is now: September 13th, 2026 - 4:28 PM |
