> V8 Turbo Drift Celica, St205 transformed into (hopefully) road legal Drift Car
post Apr 2, 2017 - 6:09 PM
darkdaywalker
Joined Jul 9, '10
From Nottingham, England
After putting a picture of my latest progress onto the 6gc FB page, I had a few people ask me to do a build thread for my 96 UK spec St205 drift car so here it is.
I bought my Celica in 2009, and decided to turn it into a Drift car in December 2016 after spending the last year going everywhere sideways in a v8 Nissan Stagea
First issue was the front subframe being smack in the way, so I had to notch it out and box it back in
Next thing that needed sorting was the gap to the firewall, sorted by cutting a massive hole, and planning to fill back in with new firewall further back
I decided I'd swap the super strut front end for a MacPherson strut off an st202 I'm breaking, so had to adapt the hubs of the st202 for the St205 front brakes to fit
I spent a whole weekend making engine mounts and welding them together and to the chassis, only to figure out later on that they wouldn't work very well for packaging reasons so Chopped them off and threw them in the bin, then came up with the crossbar under the front of the sump (don't worry there's a 7mm gap) and being solid mounted to the chassis
This weekend I've managed to get the steering rack mounted
And also managed to cut the tunnel out where needed to test fit the is200 gearbox to the 1uzfe mock up engine
The propshaft has also been cut to length with the is200 front spline and U/J ready to be welded up once I've felttled the joint a bit, no pictures unfortunately frown.gif
Future plans are fuel cell in the rear, finish up the turbo manifolds, custom wiring harness for the entire car, tube frame front end and general Drift tweaks.
'96 UK SPEC GT-4 - Blitz SUS intake, Forged Engine, Whiteline ARB, COMPLETELY Stripped out. FUN
Soon: 3inch CAT back exhaust completely empty, Refurbed Alessio Rims, HIDS, too much to list
EVENTUAL Aim: 400hp @ wheels if turbo'd 325-350 if supercharged.
Replies (1 - 16)
post Apr 2, 2017 - 7:53 PM
richee3
Joined Jun 29, '08
From Denver
This build is awesome. That is all.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Apr 2, 2017 - 10:14 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
now thats an original. i support this thread
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Apr 2, 2017 - 10:19 PM
cheela
Joined Feb 2, '07
From Berlin, WI
thank you for starting this thread on here. mad props to you for doing something totally different.
post Apr 3, 2017 - 2:26 AM
alwayzsidewayz
Joined Aug 5, '13
From England UK
Great build idea. Love it
post Apr 3, 2017 - 8:37 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
How many years have we been telling noobs about the amount of fabrication it would take to make these cars RWD?
This thread should be a sticky. Just to show the true amount of fab work needed.
Great Work OP!
~bloodMoney
post Apr 3, 2017 - 8:53 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Glad to see you made it over! I was one of the guys telling you to make a build thread.
Excited to see where this goes!
My Celica!
post Apr 3, 2017 - 10:40 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
is this going to be a slow progress build or are you guys pumping this out for a deadline?
This post has been edited by Tigawoods: Apr 3, 2017 - 10:40 AM
エキサイティングカーレーシングチーム!
post Apr 3, 2017 - 11:27 AM
Wow. You have defeated many dark theories. Awesome.
So you can swap a 2jz in a celica. In theory same process.
The firewall can be cut. And notched.....
Now in future threads asking if you can swap a 1jz ill send them here...
How safe are those welds to mount the brakes. A lot people are afraid to weld cast iron
Love the build....
post Apr 3, 2017 - 1:15 PM
Box
Joined Feb 23, '12
From Warrior, AL
Nice to see something exciting and different, look forward to continued progress.
2001 Miata LS 5-speed
post Apr 4, 2017 - 5:03 PM
darkdaywalker
Joined Jul 9, '10
@Tigawoods it's a case of as the budget allows it will be progressed, but I don't think I'm being unrealistic for my aim of doing the first shakedown run at the last Drift day of the season this year as I already have the full engine, harness, ecu, seats, pedal box and pretty much everything I need already.
@njccmd2002 I was guided through the welding of the hubs by a guy who's been doing it for 20 years, also took a small sledge hammer to it a few times and seemed completely unscathed, but to make sure will be tested on the track with no accompanying cars and my hydro handbrake for back up
It turns out in my haste to get the prop done I've fubar'd the IS200 spline/u-j so need to pick up another one of them. Bugger.
Also hoping my e46 sells so I can get a bead roller to strengthen the propshaft tunnel panels I'll be making shortly
This post has been edited by darkdaywalker: Apr 4, 2017 - 5:05 PM
post Apr 6, 2017 - 5:21 AM
darkdaywalker
Joined Jul 9, '10
Small update, manifold flanges fully welded yesterday
The heim joints for the track rods arrived yesterday
And Im going to mock up and just tack weld the propshaft with the knackered u/j just to keep moving forward
Should be test fitting the seat later today, along with seeing how the pedal box is going to be mounted, will update this evening
post Apr 8, 2017 - 11:54 AM
darkdaywalker
Joined Jul 9, '10
So I managed to get my seat mounted the other night
Even with my custom base plates I couldn't get it much lower and further back than the standard seat, but a lot more support. Steering wheel location will be around the same depth into the cabin, but a bit lower as Ill be using a quick release wheel
Putting the heim joints in the steering arms in the hubs things starting to look feasible, will probably put a slight bend in the arm to stop interference with the wheel when at minimum extension each side
A tip for everyone reading, don't buy **** for your project before you need to, I have to chop my pedal box to bits to convert it to a master cylinder under the feet design to put them far enough forward to be comfortable
post Apr 8, 2017 - 2:20 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
are you going to double sheer mount the heim joint?
QUOTE (darkdaywalker @ Apr 8, 2017 - 12:54 PM) *
エキサイティングカーレーシングチーム!
post Apr 9, 2017 - 4:38 AM
darkdaywalker
Joined Jul 9, '10
QUOTE (Tigawoods @ Apr 8, 2017 - 3:20 PM) *
Yeah, when it's at ride height that will be sorted out, as with the standard 202 front suspension it look like it's pulling a wheelie so steering rack will be lower compared to the hub mount
post Apr 9, 2017 - 5:19 AM
The_enD
Joined Apr 12, '13
Why didn't you just get a Supra?
post Apr 9, 2017 - 7:39 AM
darkdaywalker
Joined Jul 9, '10
QUOTE (The_enD @ Apr 9, 2017 - 6:19 AM) *
A) can't afford a tt 6 speed,
B) already had an St205 that no one would be interested in buying
C) already had the v8 and manual conversion
D) it's something new
Lo-Fi Version Time is now: August 25th, 2026 - 2:41 AM
