> E153 oil cooler
post Jul 19, 2017 - 11:36 PM
so my e153 has a loop line, into what i assume i can add oil cooler.
I think, i have an oem cooler with me, but would it be better to do a aftermarket?
Replies (1 - 8)
post Jul 19, 2017 - 11:50 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Google says that the 185 cooler is what you want to use if you use one, google also says you really don't need it and over cooling might make it shift like a cold trans all the time, it's pretty much for cars that are being heavily tracked or for rally racing.
post Jul 20, 2017 - 12:13 AM
lol. google. well the celi will be tracked very soon.
rollbar has been done, and baffled oil pan too.
but google does not have a celi. but i guess the oem will do... if you say so... lol...
post Jul 20, 2017 - 12:22 AM
Box
Joined Feb 23, '12
From Warrior, AL
Might look into a power steering cooler, of course they're entirely different cars but I need to get a cooler onto the Firebird since I keep boiling the fluid.
2001 Miata LS 5-speed
post Jul 20, 2017 - 7:39 AM
Bitter
Joined Mar 11, '06
QUOTE (njccmd2002 @ Jul 20, 2017 - 12:13 AM) *
I don't think you need a lot of cooling, you do want some heat in that fluid for smooth shifting. If you do run a cooler I would suggest putting an inline thermostat so you can control the fluid temp, especially if you're running the cooler up front through long lines, as the lines themselves shed heat and add to cooling capacity. Heck, just a coil of line would probably be a sufficient cooler or a big loop of line. Start small and work bigger, a Dodge minivan p/s cooler is cheap to get used to try out.
post Jul 20, 2017 - 9:32 AM
slavie
Joined May 2, '15
From NY
The best way to find out, of course, would be to stick a temp probe in the drain plug and measure the oil temp. If it's overheating, you need a bigger cooler. Same goes for PS.
ST205 stock tranny cooler is pretty beefy, and designed to handle the additional load from AWD components within the tranny. I would bet it is plenty for a front wheel drive only config. It's larger than the first few tiers of aftermarket coolers. Not sure about the ST185 one, never dealt with one.
post Jul 20, 2017 - 9:38 AM
richee3
Joined Jun 29, '08
From Denver
Would you be upset to find out that I literally just threw an ST205 trans cooler away within the last two months?
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jul 21, 2017 - 1:55 PM
I think i have one. Lol
post Jul 25, 2017 - 9:32 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
you dont need it. they came looped on the MR2 trans but have a cooler on the ST185. unless you are doing all-trac stuff, you dont need it
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: July 30th, 2026 - 4:30 AM
