> 3sgte 4th gen wiring, Trying to do the wiring on the 4th gen to a 97 gt celica 5sfe
post Sep 23, 2017 - 10:13 PM
Tmiller
Joined Sep 21, '17
From Miller42!
I am trying to do the wiring on my 5sfe to the 3sgte 4th gen need some help !
Replies (1 - 6)
post Sep 24, 2017 - 1:52 PM
Like what?
post Sep 24, 2017 - 3:14 PM
HardHead93
Joined Apr 7, '15
From New Mexico
There is not much info out there on doing the rewire because it is a JDM motor. Everyone usually sends their wiring harnesses off to WireGap or PrimeMR2. You are welcome to be the first person to document the rewire.
post Sep 24, 2017 - 6:35 PM
Tmiller
Joined Sep 21, '17
From Miller42!
I can't be that hard .. i feel like people just don't want the headache I just wanted some pointers and maybe help from someone who's done it
post Sep 25, 2017 - 9:27 AM
richee3
Joined Jun 29, '08
From Denver
Do you have your 4th gen yet? If so, lay the two harnesses down side by side to get an idea of what you need to do. These cars aren’t Hondas that are built like Legos. Toyota isn’t making it easy for you. It’s far from a case of move this wire, bridge those wires, and done. You will be disassembling both harnesses, scouring wiring diagrams, and basically building a brand new harness from the ground up. Can it be done? Sure. But consider how many hours of labor you will have in just looking at the harnesses and figuring out what needs to be done, before you actually start doing any work. Time is money, and that’s more time that your car will be off the road. If you make one single mistake, you have to pull the harness back out (which is no easy task once the motor is in the car,) and start racing every single wire to find what went wrong.
I am not trying to discourage you at all. But it is definitely a much harder and more complex job than I get the feeling you think it may be. That’s why it is absolutely worth $500 to me personally to have Wiregap do the harness so it comes back extended to the correct length, all connections are correct, no loose or broken wires, plug and play with no issues. It’s one vital part of a swap that I don’t have to worry about. Again, not trying to discourage you- just my $0.02.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 29, 2018 - 6:46 PM
trdproven
Joined Aug 2, '05
From Guam
^ very true unless time is what you have and patience.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 30, 2018 - 11:29 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
like said above, open both harness' up get the drawings for your car and the 4th gen. follow the wires and make extensions as needed. when i did the 3rd gen swap, i had to add about 2 feet to each wire. when i did the swap in my 4 runner. i ran all the wiring with the engine in the truck, then loomed wires together.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: August 23rd, 2026 - 4:23 PM
