Dec 15, 2017 - 12:08 AM
Enthusiast Joined Nov 23, '17 From Los Angeles, CA Currently Offline Reputation: 0 (0%) |
95 vert won't start with older 530 CCA or 700 CCA batteries, BOTH of which DO start/run a 97 Accord... So I don't think the batteries are 'bad'. Took one to O'Reilly and they said it checked out.
It WILL start with the application of a 600Amp battery booster jumpered though (but only if its charged to 100% - even one bar less than 100% charge and it's a no-go and sounds like a slow crank). Ideas? Has anyone experienced this or know what could be causing this problem? This post has been edited by INTRIPIC: Dec 15, 2017 - 1:31 PM |
INTRIPIC Starting Dec 15, 2017 - 12:08 AM
njccmd2002 need more info. how do you connect the booster?
... Dec 15, 2017 - 1:05 PM
INTRIPIC I connect the booster with alligator clamps to the... Dec 15, 2017 - 1:13 PM
Box Sounds like bad cables and/or grounds. That or th... Dec 15, 2017 - 1:26 PM
Bitter Likely the cables are corroded inside and making p... Dec 15, 2017 - 8:29 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 4th, 2026 - 5:13 PM |
