Jul 4, 2019 - 11:46 AM
Enthusiast ![]() ![]() Joined Apr 7, '15 From New Mexico Currently Offline Reputation: 0 (0%) |
$6000, will entertain serious offers
1997 Celica GT. It has the following: 143K miles on Chassis Gen 4 3sgte swap, swapped approx 12k miles ago Stage 2 BC Cams ATS Sweet 16 Turbo Upgraded Billet 12psi internal Wastegate BC Coilovers Kirkosaurus Front/Rear Mount inserts 5sfe ACT Clutch 3sgte Exedy Pressure Plate Lightweight Flywheel ARP Head Studs Adjustable Cam Gears MS3PRO EVO Stand-alone ECU Electronic boost controller run by ECU Conversion wiring done by WireGap 850cc injectors Walpro 255 fuel pump Flex Fuel Tune Dakota Digital SGI-5E for speedometer Koyo Radiator Polyurethane Bushings Front Mount Air to Air Intercooler 2.5 inch intercooler piping Replica HKS Blow Off Valve Air to air oil cooler Custom 2.5 inch exhaust 2 piston Avalon front calipers Drilled and Slotted Rotors Vented VIS Carbon Fiber Hood TRD Front Splitter TRD Side Skirts LED Low beam headlights and fog lights 17x8 wheels wrapped with 225/45r17 tires 300hp on 91 Octane/340hp on e85, https://www.youtube.com/watch?v=hoYzDhaDjEM&t=216s Ralco RZ Short Shifter Solid shifter cable bushings Solid shifter base bushings Glowshift Oil pressure gauge Oil/Water Temp Gauge Innovative Boost/AFR Gauge 3 pod pillar for gauges Pioneer touch screen radio 6.5 inch pioneer speakers all around GT Covers front seat covers Aftermarket Keyless entry All my spare parts come with the car too (OEM gauge cluster, OEM Fans, spare transmission, etc) I have it posted on Facebook marketplace at: https://www.facebook.com/marketplace/item/346996852866097/ This post has been edited by HardHead93: Jul 29, 2019 - 8:14 AM |
HardHead93 FS: 1997 Celica GT Convertible 3sgte swapped - SOLD Jul 4, 2019 - 11:46 AM
HardHead93 bump Jul 9, 2019 - 4:11 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 25th, 2026 - 6:14 PM |
