Full Version: Richee3's Progress thread.
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24
You might be asking yourself, "Self, how does a person who just sold their Celica make a progress thread for a Celica?" The answer is easy: you go buy another Celica. So I picked up a '96 GT hatchback with a blown engine.
The story: My brother's friend got the car brand new in '97. It's a '96 model though... gotta wait until the end of the year so you can get a good deal on a car! So back in 1997, a slate gray Celica pulls into my driveway. I've never seen one before. My brother is always telling me about how fast the car is. Flash forward a few years and I find myself with a '96 ST sitting in my garage and I find out that my brother lied to me and that these cars aren't fast at all. So here I am, 3 Celicas and a Lexus IS 300 later, and I miss my Celica. I had my hopes up for a swap and a GT4 front end conversion. So what did I do? I called Marc tonight and asked him about his old Celica. I knew he never changed the oil and never even checked it. I knew he blew the engine up. Tranny is still good, body is still good. New brakes and tires. Even has good blades on the windshield wipers. So tonight I call him and ask if he still has the car and he said he'd let it go for $250. I was there in 30 minutes with a check in hand. The car I grew up watching, the Celica that made me love Celicas, is now mine. Forgive the bad pictures, since it was night before I got there to buy the car. Better pictures coming later.
Like I said, the motor is blown. Not a big deal since I am doing a swap anyway. It was lady driven at first, and ladies suck at driving (no offense, ladies.) So she cracked the skirts and had a body shop remove them. No big deal since I am putting TRD skirts on. The car needs paint. No big deal since I was painting it anyway. Needs a new head unit... You get the idea. That's literally the extent of things that are wrong with the car. Everything else is in good shape.
Plans for the car... I'm still undecided. It's definitely getting a 3S, whether it's a BEAMS or a 3rd gen -GTE.
So... here I am, 6gc. It was a long month without a Celica, but I'm back and I'm here to stay.
____________________________________________________________
_
__________
Update: 5S-FE to BEAMS 3S-GE wiring explained with pictures:
EA1 Plug: Pins 17 and 4 need to be bridged. Pin 17 needs power when pin 4 has it. Pin 17 is in the lower left corner, black w/red trace. Pin 4 is the big black wire at the top, center of the plug. Doing this gives the BEAMS spark. Pin 17 coming off of the EA1 plug can be snipped and covered up, left alone. (See picture 1.)
EA1 Plug: Pins 2 and 12 need to be bridged. They are both ground wires, white w/black trace. (See picture 1.)
Clutch start wire: Black w/yellow trace. This one is a bit tricky to explain. There are 3 vertical plugs next to the ECU. On the body side of the plugs, you have a white (19 pin) plug, light gray (13 pin) plug, and dark gray (17 pin) plug. The clutch start wire is pin 18 on the white plug. Move it to pin 17 on the dark gray plug. (Refer to picture 2.)
• If using your OEM tach and a tach adapter, you'll need to intercept the tach signal going from the ECU to the gauges. This comes from plug C, wire 27 on the ECU plugs. It's a gray wire. (Refer to picture 3.)
Cruise control wiring: I have a 1998 USDM Celica. In my case, no wiring changes were necessary and my cruise control works perfectly. I believe that this is standard across the board of USDM Celicas, although some pre-98 models may still require changes. Further research from others is necessary.
Airbag light: To get your airbag light to function properly, you run a wire from the EA1 plug to the light gray interior plug (either pin 4 or pin 5, I have read separate posts saying both and I chose not to do this step so I cannot confirm which pin it is.)
Picture 1. EA1 plug: At the top, pins 2 and 12 are bridged together. These are grounds. In the middle with the yellow butt connector, you can see pins 17 and 4 bridged together, red w/black trace and plain black wire. At the bottom of the picture, you can see the unused and covered wire that used to be pin 17.
Picture 2. Body plugs next to the ECU. Here you can see the clutch start wire in the bottom left corner, black w/yellow trace.
Picture 3. Plug C, wire 27. This is the tach signal wire that needs to be intercepted for a tach signal adapter.
johnnehh
YES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
TEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEHEEEEEEEEEEEEEEEEEEEEEEEEEEEE
EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE!
2celicas2love
i like that color, are you going to change it? 250$? what a steal! why didn't check the oil or change the oil??! frown.gif
Thanks guys.
I am not sure about the color. It's the only Celica I have ever seen in that car. It's like a metallic slate gray color. I think Dustin's (Batman) car might be the same color. The car needs new paint anyway, so it will probably end up a pearl white or a metallic black. Yeah, it was a steal at $250. I'd be stupid not to buy it, even to just part it out. Like I said, all it needs is new paint and a new 5S-FE (What are they, like $500?)
cheela
welcome back, it's like you never left at all. hahahahah.
Johnnyny
nice
Keiri
That's a great pick-up and you'll make it shine.
Lol I thought you guys might have forgotten who I was... But apparently not! I spent a good part of last night thinking about this car and what I am going to do with it. I've decided to drop another 5S in it for right now just to get the car running again and I'll get some body work done to it, make it look the way I want it. After all, I hardly ever go to the track and street racing isn't cool. So I might as well get great gas mileage, since the Lexus isn't doing that for me. Stay tuned. Major updates on this thread coming this weekend, hopefully.
SWEET, i have been looking for a deal like this, and you just go ahead and buy one. That is a sweet color.
why not rebuild the engine? diy.
Heindrik
QUOTE (richee3 @ Apr 6, 2010 - 1:04 PM) *
I dont know if its hard to change it to a 3sge,
But i see them on Ebay sometimes, Its doesent have the turbo to maintain, it pulls great, very reliabel. Besides not many US has them, in Europa your models are also very rare wink.gif. Im glad we got the engines they use in japan in Europa though, I always wondered why the heck they made US ones different
^^^ BEams baby, no turbo, fun to drive..
but yeah, make a good desicion.
Spider77
Congrats...an IS and a new-ish project celica!
hurley97
QUOTE (richee3 @ Apr 6, 2010 - 12:27 AM) *
Thanks guys.
Dustin's car is actually a Chrysler color, similar but still very different in person.
The only 6gc I've seen in person in that color was Darin's, 6gcSTVT
It was very hard to capture the color in a picture but I think its fantastic and if you have one that's such a rare and beautiful color, just my $0.02, KEEP IT!!
I may do that, NJCCMD. I have started looking into my options. Whatever gets the car rolling again cheapest is up first. Be it a new(er) 5S or rebuilding the one that is in it now... I just want the car moving again. After that comes body work, then the fun part of the build will begin... BEAMS or 3S-GTE. Whatever I find a good deal on first. But I definitely got a good deal on the car. All it needs are things I was going to replace/redo anyway.
If you are looking for a deal like this, I know of another one for sale for $580. I chose this one over the $580 Celica because I grew up watching this car pull in and out of my driveway and because it was a little bit cheaper.
Heindrik, it is not hard to change to a 3S-GE at all. However, as NJCCMD pointed out, I would be better off with a BEAMS or a 3S-GTE. The same amount of work is involved to swap, but I get more power.
Thanks, Spider! I think the IS will be parked and reserved as a weekend car after I get the Celica up and running again. It's funny, I will be parking the car that I am making payments on and driving the one that I owe nothing for.
That's exactly the color of this car, Hurley! Thanks for posting pictures up. 6gc's are pretty rare around here, so this is the only one in this color that I have ever seen. I thought Dustin's car was the same color, judging by pictures. But I haven't decided what to do with this car. It needs paint. The hood, bumper, and roof are all faded. The rest of the body is in good shape. No dents or rust, just needs new paint. I've got a while to decide whether to keep it the same color or change it. We'll see how well it grows on me.
Wow, that color is beautiful...from the picture, I thought it was more blue-ish. I agree with Stef, respray it to the original color. thumbsup.gif
bloodMoney
I'm glad to see that you've decided to stay addicted Dan.
BTW: I've got a nice old 351 Windsor that we can throw into it biggrin.gif
Turk- I couldn't get a good picture of the car since it was well past dark and the only light I had was a dim street light and the flash of my camera. The flash definitely made the car look more blue. Hurley did a great job of getting the color though. I may have to drive my IS to her so she can capture the Intensa Blue Pearl. It's a beautiful color, but I can't get it right in a picture.
Chris- I definitely couldn't stay away. I missed my Celica too much, and it's only been a month. 351 Windsor, eh..? I don't believe that's ever been done in a Celica! I'll be in Chicago ASAP! laugh.gif
Seriously though, my thoughts for the color of this car are between a pearl white, a metallic black, the color that it is now (seems to be a favorite in this thread, so it might just stay) or I've always been a fan of the Quiksilver Supras..
I've been looking at some 5S-FE's. Looks like I can get this car and get it running again for under $1,000. First things first, getting the car here and getting it cleaned up.
GriffGirl
I just saw a 6th gen in that color by my house the other day. It's a BEAUTIFUL color in person, I'd TOTALLY rock that color. It's a really great grayish blue metallic.
QUOTE (GriffGirl @ Apr 7, 2010 - 6:52 PM) *
Did you ever get those seat covers, Michelle? This car definitely needs seat covers, and I am curious how yours turned out.
And thanks.... We won't get into that though. It's a REALLY long story.
Anyway... Back on topic. Updates. I went and got the car yesterday and brought it home. I've just spent all day cleaning it out. So much dirt that it kept clogging the filter on my vacuum and it kept overheating. But after several hours of putting various things back together and swapping the console out with one from my parts car, I'm finally back inside to show you pictures of what I am working with.
For any gold diggers out there who might have parts that they want to sell... I will be needing both high beam headlights in the not-too-distant future... Probably a driver's side seat too. Not soon, but not far off either.
The goals:
- Buy car.
- Convince the parents that buying the car is a good idea.
- Get the car back on the road for as cheap as possible.
- Fix the interior up slightly- reupholster the seats, fix the fact that I don't have a radio. At all.
- Turn towards the exterior- TRD/404 skirts, SS-III front splitters, TRD rear splitters, wingless, repaint. You guys convinced me to keep this color. JDM headlights/taillights.
- Way on down the road, engine swap. BEAMS, 3S-GTE... who knows. Either/or.
Zake
that looks like the same color as my car. my window sticker says blue slate metallic/black. (if you were wondering)
QUOTE (Zake @ Apr 11, 2010 - 6:27 PM) *
That's what the previous owner told me when I picked the car up yesterday. Slate Blue, she said. Close enough. I've noticed that the car always turns out blue in my pictures but looks more gray in person.
Ted95
3ssssssss!!!!!! lol
I took the valve cover off to powdercoat it and promote the powdercoating that I am doing for 6gc, and I found a little something. These are the spark plug wires for cylinders #3 and 4. I think cylinder #3 might have had something going on... laugh.gif
I'm pulling this motor and scrapping it anyway, so it can be just as messed up as it wants.
After talking to bmj67, I have decided to try and rebuild this motor myself. He gave me some very helpful links and the service manual. And I can't possibly mess the motor up any worse than it already is, so I might as well try. I've never rebuilt an engine before except for a single cylinder lawnmower engine a few years ago, so any tips or advice will be helpful and much appreciated.
Or I might just sell the car/part it out. Who knows.
Keiri
Dan, I say take your time and rebuild the engine - you've got a great DD and if this project doesn't pan out you can part it later.
Looking forward to more updates and I wish you the best of luck.
bloodMoney
^^^^ Werd. Learn all you can about rebuilds from this, b/c you have another car that can be used as a DD.
johnnehh
If you part it out I will drive all the way out there and backhand you.
QUOTE (johnnehh @ May 2, 2010 - 1:24 AM) *
Keiri
QUOTE (richee3 @ May 2, 2010 - 10:58 AM) *
If you sell the whole car...I'll give you what you paid for it at the least.
PART PART PART!
I mean, keep it.
If you do part it, I'LL have to backhand two people. John for attempting to backhand you, which he just can't do, and then I'd have to backhand you for selling it.
And yes, I can because that's what I have to do to keep vanilla bear in line. End of story.
Alrighty, so after contemplating selling the car, I have decided to keep it. Game on. Here are my plans for it. Looking for input/comments.
-Pulling my blown 5S, sending the cams to Crower to get a regrind.
-Get the head ported/polished.
-I will be picking up a used 5S in the next couple of weeks, and put the P/P head and cams in that.
-Intake w/ custom made heat shield.
-Ebay header.
-All new exhaust. Still 2.5", going to get a new cat put in (save the earth and all that jazz), routed under axle, into a stock muffler. Not looking for huge performance gains. I just want something quiet.
-Exedy clutch, OEM replacement.
Overall, adding a few hp, but not a lot. Just going to pep it up a little bit. The motor I will be picking up will hold off long enough just to get a 3S for the car. Inputs, advice, suggestions all welcomed.
pagii
nice richee! haha im gonna start one up too just gotta figure out how to get pics from my camera to this mac lol
Good stuff R2.
Keiri
Now this is what I like to hear!
yeah man, its easy to pull out and put in an engine.
QUOTE (njccmd2002 @ Jun 18, 2010 - 12:24 PM) *
Gonna work on it tomorrow. Wiring harness is disconnected, throttle cables disconnected, small things here and there unplugged. Just a few more things to unplug and it should be good to go. Contemplating leaving the transmission on the car, but I'll probably just pull it out too.
Small progress, but progress nonetheless. Today I kicked the Lexus out of the garage and got the Celica in. Took off the hood, a few plastic bits and pieces, hooked up a comealong to pull the engine, disconnected a few hoses here and there, opened up the car and set a fan up to help it air out, and then got hung up with a few things. So I just quit working on it and pushed it back outside. It's pretty hot and humid, and I've got to go to work here in a few minutes. Plus I'm a quitter. I know exactly what the hangup is. I was just bored with taking plastic off and I got to the fuse box under the hood and I just stopped at that. I didn't really feel like getting under the car to disconnect all the shift linkages and take the axles out and everything today. It's pretty hot. But, since this is almost an update, I have to have a picture. Cell phone quality FTW!
Also discovered another new problem. One of the wheel studs is broken on the back right wheel. 1.) New parts FTW! and 2.) This is the same problem that started a chain reaction with my black Celica that finally resulted in me selling the car. So... I'm gonna rub this in my dad's face. And then he will NOT help me fix it like last time laugh.gif
Just a couple more pictures of a few things.
Pretty sure these are the original spark plugs that came in the car. They look nice and toasted. I was able to loosen the spark plug on cylinder #1 by hand.
Just so you guys know, it smells rotten inside this engine. Took the valve cover off, started to take the cams out, and every time I broke one of the bolts loose that hold the cams in, it released a smell of rotten... female genitals. It's pretty rank. Let this be a lesson to you n00bs out there. Always do your maintenance and change your oil, or else you'll get to deal with the same things I am right now.
pagii
"Took the valve cover off, started to take the cams out, and every time I broke one of the bolts loose that hold the cams in, it released a smell of rotten... female genitals' -richee3 hahaha favorite quote for the weekend lol dude at least your making progress i cant start till monday tongue.gif
wow look at all that nastyness.
Keiri
Dan,
That looks filthy...and the description is wondrous. Haha.
Don't let the boredom stop you - just be persistent and have some good music going as you work.
Told you guys that maintenance wasn't at the top of the list for the previous owner... At any rate, a project car just isn't a good one unless you get dirty. This car is definitely getting me dirty.
I've always got a good playlist going when I work! I can't stand working without music. This project is back on hold for a little bit, since it'll be a week before I have an entire day off to work on it again. I'll probably have some help next time, so that'll keep me motivated as well. Hopefully next time I update this thread, it'll be with pictures of an empty engine bay.
any news?
Took another look at the fuse box.. It was incredibly easy. Can't believe I missed that the first time. Two plugs. All that remains now is to disconnect the shift linkage, a couple more hoses, and a the motor mounts, and that engine will be out. The exhaust cam is out and cleaned up, ready to be shipped to Crower, but the intake came is being a little more stubborn. I will hopefully be down there to pick up your engine in the next week, maybe two. I was thinking about it today and realized it would be pretty stupid of me to pull the engine out of the car, go pick up a new engine, and put it in later, so I'm going to try to be smart about this and pull my engine and drop yours in in the same day. Before I drop the new motor in, I'd like to get the batter officially relocated to the trunk. Just need to pick up some wiring and read up on that a little bit more.
stephen_lee
go dan!
we got swaps going around the same time
Bigblock
richee3---
I see you've been bitten & you can't shake the venom---
No doubt this is going to be another class Celica brought back to life!!
Best to ya!!!
Why have I taken the covers off of my seats? And why have I bought a bunch of 4 gauge power wire?? Could there be a real update coming soon???
Johnnyny
Spider77
You took off the cover so you can take out some crappy stock padding and install "memory foam" (developed by NASA you know) for a firmer, yet comforting ride?
you bought leather and relocating the battery
