7 Pages V  « < 2 3 4 5 6 > »
> CAI GT how to., 20 to 30 bucks
post Oct 14, 2005 - 1:02 AM
blu94gt
Joined Mar 23, '05
From Kansas City
QUOTE(Boss-Celica @ Oct 13, 2005 - 5:22 PM)
QUOTE(Bigmeanbulldog55 @ Oct 13, 2005 - 10:13 AM)
Is that a 96 engine in your car Boss-Celica?  I have a 94, and I've never noticed the differences before.  I thought the set up was almost the same with all the 5sfe motors.  My egr valve is different, and that vent hose coming out of the valve cover.
[right][snapback]344154[/snapback][/right]
I see what you are talking about. I think they did do some minor adjustments from the 94 to the 96.
[right][snapback]344342[/snapback][/right]
weren't the adjustments made in 1996 to help accomodate the OBDII requirements? That makes sense to me at least
1999 Celica GT
post Oct 14, 2005 - 3:35 AM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE(Bigmeanbulldog55 @ Oct 13, 2005 - 2:13 PM)
ive got a 95 and it has that breather hose off the valve cover too.
post Oct 14, 2005 - 10:45 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(urbandork @ Oct 14, 2005 - 4:35 AM)
[right][snapback]344532[/snapback][/right]
Were does it go off the valve cover? Does it look like BossCelica's? Or does it go to the throttle body?
Live Free, Be Happy
post Oct 15, 2005 - 8:46 PM
urbandork
Joined Jul 16, '04
From Los Angeles
valve cover to TB and there was another from the back of then engine to the pipe. but seeing as they both suck before the butterfly valve it probably doesnt matter.
post Oct 15, 2005 - 11:13 PM
snowbunny
Joined Jun 30, '05
From Modesto, CA
QUOTE(Redline_Racer @ Feb 24, 2005 - 12:12 AM)
Awesome bro here is mine, I made it out of Mandrel Bent Piping, and hand polished it it cost me around 80 to make.
-Brandon
[right][snapback]249571[/snapback][/right]
Nice setup, now scrub that engine bay and your battery needs some TLC.
Where did you buy the parts from?
1994 Celica GT Hatchback
17" Konig Tantrum Rims
Khumo Ecsta Lo-Pro's
New Brakes / Rotors!
15% Tint
post Mar 15, 2006 - 7:47 AM
urbandork
Joined Jul 16, '04
From Los Angeles
Its been discovered that this cai also works for st's heres the thread
http://www.6gc.net/forums/index.php?showtopic=34158
post Mar 15, 2006 - 5:12 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
hey cool... i'm a part of the sticky.
post Mar 15, 2006 - 9:22 PM
pimpstarr690
Joined Jul 19, '04
From Strongsville, Ohio
Im just putting this out there....Saves you time and the hastle...ebay
My Twins!
post May 8, 2006 - 9:18 PM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
Yay I put mine in today... there are some adjustments that need to be made but it is fine for now. I also had an idea. Where the filter comes out in the fender, what if a 90 degree was put in there to make the cone sit horizontally in the fender. Depending on the feedback, I am going to try it.
post May 8, 2006 - 9:48 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
looks good chucks, hows it sound? i know youve had stock airbox for a while haha
post May 9, 2006 - 1:07 AM
j0e_p3t
Joined Dec 8, '05
good job. where's your battery?
post May 9, 2006 - 10:19 AM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
QUOTE(j0e_p3t @ May 9, 2006 - 2:07 AM) [snapback]431860[/snapback]
I wasnt done when I took those pics , the battery is back in now smile.gif And it sounds really nice, not too loud but I can definitley hear it!
post May 9, 2006 - 5:51 PM
j0e_p3t
Joined Dec 8, '05
oic. now get a bypass filter.... just in case.
post May 26, 2006 - 1:07 PM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
where is a good place to get a by-pass filter?
post May 26, 2006 - 1:59 PM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
ebizzle
post Jun 6, 2006 - 10:37 AM
Negative
Joined Apr 28, '04
From Houston, Texas
I just noticed that the hole between the stock air box and the fender is different on my '99 GT than ya'lls is. Mine is farther back towards the suspension and a little easier to get to. I will post a pic when I can. Strange that they changed something so trivial in the later years. I can say that it would be easier to route piping wise but it would require cutting a larger diameter or using smaller than 2.5" piping (not a good idea IMO).
All in all I just decided to stay with my 3" short ram run to the hole and left the stock lower airbox and piping so it would get at least some cold air.
The reason why is I sucked water into my engine when the car was stock and it really sucked getting it out and then having to change the oil before driving the car again. How does a bypass valve prevent this? If it works 100% I may decide to CAI just for the f*ck of it since CAI vs. Short ram is a minimal difference at best anyway.
post Jun 8, 2006 - 10:22 PM
j0e_p3t
Joined Dec 8, '05
i'm pretty sure a bypass valve prevents hydrolock 99.99% of the time. its like a seperate mini air filter that works when your normal filter is submerged in water.
post Sep 21, 2006 - 8:56 PM
vozizm
Joined Sep 18, '06
From North Carolina
HOLD UP!!!
All i have to nuy is a Accord 90-93 CIA kit and bypass valve and i can make this happen wif above instructions...
What are some of the HP gains?
VOZ™
post Sep 22, 2006 - 8:07 PM
vozizm
Joined Sep 18, '06
From North Carolina
I take it this one will work with this mod?
VOZ™
post Sep 22, 2006 - 8:19 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
if you get the accord cai, most the time the 2 pipes are different sizes so it would be difficult to use a bypass valve, get a one piece aem version, cut in the right location, add the bypass valve as a coupling.
Lo-Fi Version Time is now: September 8th, 2026 - 5:37 AM
