> How to do - installing 96-99 fogs, instalation of stock foglights
post Jun 26, 2006 - 2:02 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
I'm sure I can't beat azian_advanced and his "how-to-do"s wink.gif, however I belive at least one person will appreciate that (am I right Tina? biggrin.gif)
Let's do some work...
1. useful equipment wink.gif :
a) well known fog lamps
part numbers:
R 81210-20280
L 81220-20270
b) lamp brackets (you can also see already installed fog light wire from factory! just plug-and-play)
part numbers:
R 52015-20310
L 52016-20150
c) 6 screws (I don't know what "international marking" is, but we call them "size 10")
2. checking some details... If you want install them "by the book" you will need:
a) fog light relay
b) fog light switch
c) fuse (20A)
locations...
relay...
switch...
and fuse...
part numbers:
*if you don't want to pay that amount see "second choice" way at the end (point 5) wink.gif
3. switch swap, easy thing, just screwdriver needed... remove all necessary screws, disconnect plug with wires and just pull multi-switch out... For relay you will not need any tool. Just plug it in (it's "dumb-proof", can't plug it wrong wink.gif biggrin.gif )...
5. "second choice" way. If you don't want to spend money for multifunctional switch swap and relay, just buy any switch/button and rake up some wires...
a) wires connect like this... (short circuit of contacts shown below, turns your foglights on wink.gif)...
b) ...and if you add to the "short circuit" any switch...
***warning*** : if you forget turn your foglights off (leaving a car), you kill your battery! There is no "warning sound" like headlights has...
This post has been edited by malpaso: Jan 26, 2013 - 3:34 PM
- malpaso   How to do - installing 96-99 fogs   Jun 26, 2006 - 2:02 AM
- - JFrost9   This is awesome, i guess the only thing that could...   Jun 26, 2006 - 3:18 AM
|- - malpaso   QUOTE(JFrost9 @ Jun 26, 2006 - 10:18...   Jun 26, 2006 - 3:31 AM
- - trdproven   not my 94 gt. no wires. maybe usdm has no harness...   Jun 26, 2006 - 6:49 AM
- - malpaso   I instaled two foglights this weekend (both 96 ST,...   Jun 26, 2006 - 7:00 AM
- - azian_advanced   nice write up malpaso! does anybody know w...   Jun 26, 2006 - 7:13 AM
|- - malpaso   QUOTE(azian_advanced @ Jun 26, 2006 - 2...   Jun 26, 2006 - 7:34 AM
- - jdg371   I would check my car if it has the wires but its r...   Jun 26, 2006 - 7:37 AM
- - ILuvMyCelica95   awww thanks! My car doesnt have any wires f...   Jun 26, 2006 - 11:41 AM
- - snapshotgt   Firstly, that was a great write-up! Just to...   Jun 26, 2006 - 12:11 PM
- - CelicaQT   Is it possible to sticky this or add this to the ...   Jul 15, 2006 - 5:19 AM
- - JFrost9   snap do you have any more info on the install? I ...   Jul 15, 2006 - 2:14 PM
- - presure2   GREAT job man! added to the sticky!   Jul 16, 2006 - 10:46 AM
- - vile_v   The two pins on the fog lights that go into the br...   Jul 22, 2008 - 12:35 AM
- - Euphoria   I did the second option and it works, thanks . wha...   Aug 19, 2009 - 10:45 PM
|- - whatthe   QUOTE (Euphoria @ Aug 20, 2009 - 1:4...   Aug 19, 2009 - 10:51 PM
- - Euphoria   yeah bro, fully sick uleh, I think fog lights are ...   Aug 20, 2009 - 10:06 AM
- - Euphoria   anyone?   Aug 22, 2009 - 2:02 AM
- - SwissFerdi   Mine are aftermarket as well (judging by the non-s...   Aug 22, 2009 - 2:41 AM
- - 96stgreendemon   ok just to be clear, you only use the 2 prongs on ...   Nov 20, 2009 - 6:32 PM
- - UniqueGT4   Where can I get the fogs for tha 94-95 celi   Oct 4, 2010 - 9:01 PM
- - pick-up_man   Would this be something I could put onto a '94...   Jan 18, 2011 - 1:19 AM
- - CAcelica29   question: since im wiring oem fogs on a 95, i dont...   Feb 4, 2012 - 6:16 PM
- - rodriguez046   Im getting foglights for my 95 celica and i have ...   Mar 17, 2012 - 11:54 PM
- - CAcelica29   auto parts stores usually sella cheap and easy kit...   Mar 18, 2012 - 10:53 AM
- - CelicaZR   Just want to say thanks to Malpaso for this guide ...   Jul 1, 2012 - 9:01 PM
- - Kobragijoe   Hi, I need to know what kind of relay do i need fo...   Jan 25, 2013 - 10:49 PM
- - CelicaZR   i can see the pics fine   Jan 28, 2013 - 7:04 AM
- - Toyo6g   I'm pretending to do this swap.... I already h...   Jul 4, 2013 - 10:48 PM
|- - richee3   QUOTE (Toyo6g @ Jul 4, 2013 - 10:48 ...   Jul 5, 2013 - 5:36 AM
- - Toyo6g   From where so I have to star the wiring??   Jul 5, 2013 - 10:22 AM
- - MIRVops   So as long as you don't have the multi functio...   Jul 17, 2014 - 11:35 AM
|- - Toyo6g   QUOTE (MIRVops @ Jul 17, 2014 - 12:3...   Jul 31, 2014 - 11:41 PM
- - JK89   Hi, sorry to bring up an old thread but i need hel...   Jun 19, 2017 - 1:09 PM
- - Bushmatic   I know how old this thread is, but I just want to ...   Sep 8, 2017 - 8:18 PM
Lo-Fi Version Time is now: September 17th, 2026 - 10:13 PM
