Oct 22, 2006 - 6:52 PM
Enthusiast ![]() ![]() Joined Mar 25, '06 Currently Offline Reputation: 0 (0%) |
Just thought i'd post this incase any ST owners wanted an idea of how to run their wiring. I like my car clean so this install took ~ 2.5 hrs, that, and the fact im not very mechanically inclined.
RELAY + GROUND *Mounted near centre firewall, there was a screw hole there. I found a screw that fit from my tool box and mounted the relay.* ![]() ![]() WIRING TO R HEADLIGHT +WIRING TO BATTERY *Ran the wiring to the positive battery terminal under the air filter box, and up the positive sheath. Unscrewed the positive lead that goes to the engine, inserted my positive wire and rescrewed the bolt. Wiring to R headlight went between the air box and the body. Didnt even have to use zip ties here. Also this i where i plugged in the wire that had to goto your old light wiring. ![]() ![]() ![]() ![]() BALLAST R Look carefully below my battery, under coolant line. Mounted with double sided tape (first i cleaned both surfaces with alcohol) and zip tied it incase the tape ever comes loose. ![]() WIRING TO L HEADLIGHT This wiring followed the tubes that run along the firewall all the way up to near the headlight ![]() ![]() ![]() ![]() BALLAST L Easiest mount by far. Double sided tape + zip ties to mount to body part right under relay box. ![]() FINAL PRODUCT + NOTES In total i used about 25 zip ties to hold the wiring to places car. Dont be afraid to use too many, just make sure you snip the ends off after and rotate the ties so you cant see the stopper (i know, im obsessive compulsize). Also, when inserting the bulbs there is only ONE correct way to put them in, so double check you are inserting them right the first time. I had to re-insert a few times and im sure it took a bit of life off my bulbs! Double check your wiring, let loose your clutch (keep e-brake on) and take a look. This is with high beams on so i can see the contrast! Hope this tutorial-ish is useful for someone. ![]() ***Picture taken before i secured my wires, just to test lighting. My wires do NOT run over the battery like the picture would imply*** NIGHT SHOTS Color looks nice eh? ![]() ![]() ![]() This post has been edited by phonex98: Oct 22, 2006 - 9:33 PM -------------------- ----- '94 ST hatch --- Yellow ----- |
Oct 22, 2006 - 7:21 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 28, '04 From St.Louis Currently Offline Reputation: 15 (100%) |
WOW! that is a great write up, i got my kit but i havent taken the time to look at how i was going to mount it. Now i know EXACTLY how. once again great write up.
I vote sticky this post. This post has been edited by 94celicadude: Oct 22, 2006 - 7:21 PM -------------------- ![]() 1994 GT Hatchback 1994 ST Coupe 1988 Corolla Wagon All-Trac 1999 Corvette 2008 Cobalt SS Turbo |
Oct 22, 2006 - 7:38 PM
Thanks bud
This post has been edited by phonex98: Oct 22, 2006 - 7:39 PM -------------------- ----- '94 ST hatch --- Yellow ----- |
Oct 22, 2006 - 8:11 PM
Enthusiast ![]() ![]() Joined Apr 11, '06 From Tasmania Currently Offline Reputation: 0 (0%) |
Cool write up you should make it a How-to
I want HID in my SX -------------------- Ok Gladys, lets play house, you be the door and I'll shut you.
Oct 22, 2006 - 9:02 PM
there has been a lot of info about installing HIDs lately because of the GB, here are some more links with install info
http://www.6gc.net/forums/index.php?showtopic=42363 http://www.6gc.net/forums/index.php?showtopic=42381 http://www.6gc.net/forums/index.php?showtopic=42353 -------------------- |
Oct 22, 2006 - 9:26 PM
we should somehow combine them... and make a super how to
Oct 22, 2006 - 9:43 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
wow... everybody's getting hid's nowadays.. nice.
Oct 23, 2006 - 10:48 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
i really needa clean up the wiring in my engine bay... it's a mess rite now
Oct 24, 2006 - 8:18 AM
good job man! added to the stickys!
Feb 19, 2007 - 1:00 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 28, '06 From Brooklyn, New York Currently Offline Reputation: 1 (100%) |
Hey dude, what relay and fuse did you use?
Feb 19, 2007 - 1:07 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) |
QUOTE(LeonStryfe @ Feb 19, 2007 - 1:00 PM) [snapback]528319[/snapback] Hey dude, what relay and fuse did you use? the relay he used was included on the HID kit of previous orders, they stop including this harness as it was an alternate wiring method, and the kit perform just fine with standard installation -------------------- ![]() |
Feb 21, 2007 - 3:54 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 8, '04 From Thornton, CO. Currently Offline Reputation: 1 (100%) |
How much did everyone pay for their HIDs?
-------------------- Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..." ![]() |
Feb 21, 2007 - 3:56 PM
QUOTE(FreddyTheOthaMeat @ Feb 21, 2007 - 3:54 PM) [snapback]529120[/snapback] How much did everyone pay for their HIDs? look at it yourself HID GB -------------------- ![]() |
Jan 17, 2009 - 7:33 PM
Enthusiast Joined Jan 17, '09 From CA Currently Offline Reputation: 0 (0%) |
Hello
How did u do your high beam did u just leave it alone? Did u use both wire from stock or just the red to go into your relay? |
Jan 17, 2009 - 11:52 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) |
I' am impressed that this car looks like its out of the lot ! Impeccable!
-------------------- ![]() -Rémy 02 SiR, 08 250R |
Aug 21, 2014 - 8:50 PM
Enthusiast ![]() ![]() ![]() Joined May 10, '14 From Tulsa, OK Currently Offline Reputation: 5 (100%) |
Hello sorry to reserect an old thread but I cannot see any pictures. Is there any way to refresh those?
| Lo-Fi Version | Time is now: September 19th, 2026 - 4:57 AM |
