> Brembo front rotors installation, how to...
post Feb 19, 2007 - 4:06 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
I have decided change my brake rotor to better ones and here is my story biggrin.gif
not cheapest but reasonable price for "plug-and-play" part.
2. removing wheel
nice to have tools...
- usual tools for wheel take off
- something for stubborn screws (like WD-40)
- hammer (handy every time biggrin.gif)
- wrench 17 and 14
3. removing caliper
by those two screws remove caliper away...
...by two wrenches (like picture below showing... one for holding, and second for un-screwing... sorry I can't describe that better kindasad.gif)
4. removing brake pads and caliper mounting
remove pads is easy, that hardest part are caliper mountings held by two screws...
those two bolts were rusted and stubborn unbelievably!!! W/o WD-40... (and hammer help sometimes) it could not be done... my car almost fell off the lifting jack during that kindasad.gif.
5. removing rotor
nothing but rust holds that disc -> just gently knock on and it fell off...
you can see all that rust (after hammer work smile.gif) and really bad condition of inner part of rotor.
6. just make it look good and re-assemble everything...
now it's done... just put everything back on (plus in my case use some direct-to-rust-metal-paint for rusted parts).
note: you maybe would need push back caliper piston if new rotor is wider or you change brake pads (recommended) by some pliers like this:
(I don't know how you call that)
plus:
QUOTE(azian_advanced @ Feb 19, 2007 - 4:42 PM) [snapback]528279[/snapback]
...just as a tip, lubricate the inside of the pistons inside the rubber seal.
And results you can see below smile.gif:
This post has been edited by malpaso: Feb 20, 2007 - 1:56 AM
post Feb 19, 2007 - 6:29 AM
Slick
Joined Jan 10, '06
From Mozambique, Africa
What made you go with these rotors rather than the slotted/grooved type?
post Feb 19, 2007 - 6:38 AM
malpaso
Joined Feb 3, '06
QUOTE(Slick @ Feb 19, 2007 - 12:29 PM) [snapback]528223[/snapback]
post Feb 19, 2007 - 7:25 AM
6strngs
Joined May 12, '06
From Wilmington, NC
ah, you beat me to it. I was gonna do a write up when I did my brakes, I have the pads and rotors in my garage I just need to get my darn wheel locks off!
anyway, you forgot to mention that when compressing the caliper piston you need to pull the cap off the brake fluid resevoir in the engine bay, otherwise it won't compress.
post Feb 19, 2007 - 7:37 AM
Slick
Joined Jan 10, '06
QUOTE(malpaso @ Feb 19, 2007 - 1:38 PM) [snapback]528227[/snapback]
Aah, i see. Good choice!
post Feb 19, 2007 - 10:42 AM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE(6strngs @ Feb 19, 2007 - 6:25 AM) [snapback]528241[/snapback]
and just as a tip, lubricate the inside of the pistons inside the rubber seal.
post Feb 20, 2007 - 1:54 AM
malpaso
Joined Feb 3, '06
QUOTE(6strngs @ Feb 19, 2007 - 1:25 PM) [snapback]528241[/snapback]
Not necessary. There is relief valve which can handle that w/o pulling cap off
...and just as a tip, lubricate the inside of the pistons inside the rubber seal.
post Feb 20, 2007 - 11:18 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
post Feb 20, 2007 - 11:26 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
I want to know how you like those rotors (not that they make them for us in the US cause they probably don't, but in case they eventually do I would want to get them)
I <3 Dustin---07/16/06
post Feb 21, 2007 - 5:00 AM
malpaso
Joined Feb 3, '06
QUOTE(hurley97 @ Feb 21, 2007 - 5:26 AM) [snapback]528899[/snapback]
IMO everything is just about your choice wink.gif You may try contact Brembo branch in US here:
27280 Haggerty Road, Suite C-20
Farmington Hills, MI 48331
Phone: (248) 489-9197
...and order Brembo max rotors part number 368 2528 cuz Euro and US STs has the same rotors.
If any problem occurs smile.gif:
- Price in my country is $170 for pair
- Insured shipping CZ-US for package up to 10kg: $125 priority air mail (3-5days), $50 economic air mail (5-10days)
that means: $220 + two weeks and you have them home wink.gif
post Feb 21, 2007 - 3:16 PM
wind
Joined Nov 4, '03
From Vancouver, Canada!
i hope you replaced the brake pads as well....
post Feb 22, 2007 - 3:26 PM
trdcelica94
Joined Apr 29, '03
From socal
how much did those brembo cost at the dealer?
post Mar 10, 2007 - 8:06 PM
Rockford
Joined Dec 22, '06
From Caracas-Venezuela
Malpaso what kind of brake pads do you buy??? for which model???? i got problems with mines frown.gif
Celica ST202
post Mar 11, 2007 - 1:57 AM
6strngs
Joined May 12, '06
From Wilmington, NC
I did my front and rears today. sorry, I didn't take any pics during the whole thing. but basically, if you want to change your rear discs:
1: make sure your emergency brake is not set!!!
2: jack the car up and remove the wheel
3: remove the one 12mm bolt on the bottom of the caliper (you don't need two wrenches like you do on the front, and there is only one bolt, not two)
4: remove the two 14mm bolts holding the caliper onto the rotor (pretty tightly on there, and kinda hard to get to. I had to use a deep socket to get the top one, and a short socket to get the bottom)
5: pull the caliper off, it kinda flips open instead of coming apart in two pieces like the front
6: pull the rotor off. if it doesn't want to budge you can take the long 12mm bolt you pulled out and screw it into one of the two holes that are near the center of the rotor to push it off.
7: compress the caliper, it's easiest with a c-clamp, but a big pair of pliers will work too. or whatever other tools that you have laying around that you think could push the piston back in. just make sure you either open the lid on the brake fluid resevoir or open the bleeder valve on the caliper first.
8: put your new rotor on
9: put new pads in
10: put the 14mm bolts back in
11: put the 12mm bolt back in
12: put the wheel on and lower the car
13: break the new pads in with 2 or 3 hard stops (I think it is recommended you go 45mph and brake to a complete stop, at least with hawk pads)
enjoy!
post Mar 11, 2007 - 3:23 AM
malpaso
Joined Feb 3, '06
QUOTE(Rockford @ Mar 11, 2007 - 2:06 AM) [snapback]535109[/snapback]
Pads from one German manufacturer (http://www.textar.com/). Direct replacement.
This post has been edited by malpaso: Mar 19, 2007 - 2:06 AM
post Mar 11, 2007 - 4:24 AM
TomPoz
Joined Nov 25, '04
From Warsaw, Poland
Good write-up, Martin. I will use it when putting my spacers on.
'94 ST202 - tuned, highly apprieciated, but sold.
'99 ST205 - imported, legalized, Stage 1 completed.
For slow driving: Yamaha XVS650 Drag Star.
The most recent addition to the family and for the family: Toyota RAV4 2.0 VVTi
Celica-Club Poland - Everything you want to know about your favourite car ... in Polish
post Mar 11, 2007 - 5:25 AM
Alan
Joined Jan 23, '05
From Malta
Nice Martin. Did you Do it alone? Nice one man
post Mar 12, 2007 - 1:46 AM
malpaso
Joined Feb 3, '06
QUOTE(Alan @ Mar 11, 2007 - 11:25 AM) [snapback]535202[/snapback]
yes Alan, all alone smile.gif.
QUOTE(TomPoz @ Mar 11, 2007 - 10:24 AM) [snapback]535198[/snapback]
Thank you Tom smile.gif.
post Mar 12, 2007 - 1:52 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Rockford @ Mar 10, 2007 - 5:06 PM) [snapback]535109[/snapback]
I used Hawk HPS pads front and back and had no problems.
post Mar 18, 2007 - 11:32 PM
kamax
Joined Apr 29, '03
From lynn,ma
thanks for the write up... was so easy, i decided to give it a try. except i did it when it was cold and snowy... no garage sucks =p
Lo-Fi Version Time is now: August 2nd, 2026 - 3:04 PM
