> No spark + New Battery = ?, Any ideas on what order to check
post Jul 27, 2007 - 7:27 PM
garygarrett1
Joined Jul 25, '07
From Frisco, TX
Ok the diagnostics begin, anybody have a list for me to run down that will help me isolate what the problem could possibly be.
'94 7afe ST (MT)
I have a new ECU on the way (thanks to illneversellmyceli)
any way as a newb to celica's and mechanically not the most rounded individual, what would be the obvious starting points other than the battery.
Replies (1 - 16)
post Jul 27, 2007 - 7:38 PM
Culpable04
Joined Apr 17, '06
From New Jersey
first step .
determine Check engine light code !
hopefully this ECU will tell you what's wrong. based on that people here will guide you to the next step.
post Jul 27, 2007 - 11:06 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
sparkplugs, wires, and distributor cap. then check connection on battery
post Jul 28, 2007 - 7:50 AM
garygarrett1
Joined Jul 25, '07
From Frisco, TX
Ok, so i put the key in the on position and no check engine light! I am looking through the Haynes manual and don't see anything.
Ideas?
QUOTE(Culpable04 @ Jul 27, 2007 - 7:38 PM) [snapback]583076[/snapback]
first step .
post Jul 28, 2007 - 12:13 PM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
QUOTE(garygarrett1 @ Jul 28, 2007 - 7:50 AM) [snapback]583165[/snapback]
Ideas?
first step .
I had the same a while ago.
Found out it was a broken fuse/relais for the efi. It is located in the fusebox near the battery. Its's the blue one
You can hotwire it, atleast you can still drive then till you get a new one
JDM ST205
post Jul 28, 2007 - 4:55 PM
garygarrett1
Joined Jul 25, '07
From Frisco, TX
ok i pulled that relay and it looks ok, how do you test it?
post Jul 29, 2007 - 1:59 PM
nsxtypeR
Joined Jan 3, '06
Leave the relais out of the car, then you've got to bridge the 2 pins that supply 12V to the relais. When you turn on the ignition, the cel will appear on the dash and you 'll be able to drive again.
I'll try to post some pics tomorrow
JDM ST205
post Jul 29, 2007 - 2:16 PM
garygarrett1
Joined Jul 25, '07
From Frisco, TX
QUOTE(nsxtypeR @ Jul 29, 2007 - 1:59 PM) [snapback]583416[/snapback]
Ok i will try that when I see what you are referring to,
Today:
New + & - Battery cables
New Iridium Spark plugs - Bosch (bty there was some oil in the center two plugs? Bad head gasket?)
Starter is now turning but not getting any ignition
thoughts?
post Jul 29, 2007 - 2:20 PM
haha, no ... bad valve cover gasket.
post Jul 30, 2007 - 8:27 AM
garygarrett1
Joined Jul 25, '07
From Frisco, TX
Had my post about buying spark plug tubes deleted mad.gif so I guess I will ask the question here. Does anyone know where to source the tubes?
With all the reading I have done, it seems to be a fairly common problem and none of the stores I have searched (autozone, pep boys, wal mart) carry these tubes.
post Jul 30, 2007 - 8:31 AM
Culpable04
Joined Apr 17, '06
From New Jersey
I didn't get to see the post, but most likely was deleted because it wasn't properly tittled.
make sure when you make a post on the buying and selling section it has
WTB ( want to buy )
or
FS ( for sale )
or
WTT ( want to trade )
that should be in front of your tittle, is the first thing you right so people know what kind of transaction you're looking for.
as for the tubes
go to toyotaworld.com and check the price may not be too much.
This post has been edited by Culpable04: Jul 30, 2007 - 8:31 AM
post Jul 30, 2007 - 11:33 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
are you getting fuel? if neither spark nor fuel then you should check connection to the distributor, since thats where both of those are tied to. no cps signal means no spark and no fuel, but as said before check ALL fuses and the efi/htr relays.
post Aug 6, 2007 - 8:58 AM
garygarrett1
Joined Jul 25, '07
From Frisco, TX
QUOTE(Bitter @ Jul 30, 2007 - 11:33 AM) [snapback]583690[/snapback]
OK here's where i stand, new ECU is in (huge pain in the A$$ mad.gif ), New battery cables, New Spark plugs, CAI installed (another huge pain in the A$$ mad.gif ), took distributor cap and plug wires to autozone and had them tested to make sure they were ok (all good biggrin.gif )
Now I can get it to crank but again no spark - what the hell am i missing here?
post Aug 7, 2007 - 6:55 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
are you actually pulling the plug and seeing no spark?
as in pulling thte plug out, connecting the wire, and touching the base of the plug to a good ground as the car is cranked. if its blue, its good, orange is weak. and obviously bo spark is bad.. check the coil?
post Aug 7, 2007 - 8:53 AM
garygarrett1
Joined Jul 25, '07
From Frisco, TX
QUOTE(stephen_lee @ Aug 7, 2007 - 6:55 AM) [snapback]585993[/snapback]
I pulled the plug wire going into the distributor and laid it just inside to get connection and watched for a spark when cranking and nothing zip zilch notta.
post Aug 8, 2007 - 6:01 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
then most likely the coil is bad.
check the connections to the distributor first, though.
post Aug 13, 2007 - 3:01 PM
garygarrett1
Joined Jul 25, '07
From Frisco, TX
rolleyes.gif so I tried the paperclip thing and blew three additional fuses kindasad.gif
So I am assuming that it's not the relay and it HAS to be the coil?
Lo-Fi Version Time is now: August 30th, 2026 - 11:48 PM
