> Suspension Techniques sway bars and endlins, suspension is perfect at last... pictures inside!
post Sep 7, 2008 - 4:02 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
First of all I would like to say BIG THANKS to Batman722... w/o him I had no chance get those parts to my country.
...and of course to author's of how-to articles (really handy especially for rear...)
http://www.6gc.net/howto/install_front_sway_bar
http://www.6gc.net/howto/install_rear_sway_bar
Now I would like to share with some more details (maybe useful for other people as well) that surprised me during installation...
a) I can not imagine that installation w/o decent jacking system and having car lifted really high. Though complete installation took about 4hrs (that's double than announced in how-to articles)
b)
I found out old rear sways were rusted as hell...
...but front not at all. Dunno why...
c)
rear endlikns were easy to remove... but front ones...
...on both sides had to be removed really violently (by cutting off the nuts)...
d) advice in how-to article about loosening tank and muffler was necessary even for me with custom exhaust pipes cuz I really had no chance pull old bar out of there w/o that step...
e)
that "oversteer" question... (Quotation from how-to article) "The holes closer to the end of the bar can be used if you want more oversteer, but if you don't want as much oversteer, use the inside holes that are closer to the middle of the bar.". What is that "oversteer"? I have used those holes closer to the end because arm of sway bar was more horizontall that way (I hope you know what I mean)...
f) and last "issue" was with those new front endlinks... What direction is correct? With that nut up or down? Or it doesn't matter? I hope I have not them installed upside-down...
Any comments appreciated! Thanks...
This post has been edited by malpaso: Sep 11, 2008 - 2:20 AM
post Sep 7, 2008 - 6:31 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
right on man biggrin.gif i bet the car handles like a dream wink.gif im thinking about getting this too.
how hard was it to take out the old ones and put in the new ones???? Colin told me that it might be hard to put on since its fatter and stiffer kindasad.gif
post Sep 7, 2008 - 9:29 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
due to the fact that the allen key holes on the original endlinks will most likely be rusted, there will be no other solution but to cut them of which isnt too hard.
the two things during installation that were a problem for me where threading the new sways through.
and tightening the new bushings. (the new bolts for the sway bushing clamps are allen key only, and i didnt have an allen key adaptor for my socket so i sat there for an hour and a half tightening these bolts little by little in the cramped space) GET A SOCKET ADAPTOR!!!!
also for those who didnt figure this out or who didnt have needle nose pliers.
** the section in the how-to article where it explains that you have to use pliers and an allen key to take off the end link bolts...is too complicated of method. all u have to do is get an allen key and a fixed 14mm wrench and turn them the opposite directions until the nut is off
This post has been edited by Tigawoods: Sep 7, 2008 - 9:34 AM
エキサイティングカーレーシングチーム!
post Sep 7, 2008 - 10:48 AM
how does it feel driving with them compared to the stock set up Martin ?
post Sep 9, 2008 - 10:27 AM
malpaso
Joined Feb 3, '06
To 808celica: fatter is only rear one and in my opinion front is almost the same. Still I had no problem put the new ones in. It's exactly as how-to articles describes smile.gif
To Tigawoods: that allen key you mean socket-screw key right? I had the same issue... honestly I dot have any idea why they have been using them at all... So I have used old screws I had there.
To Batman722: Dustin... I'm so surprised how much can "stupid" sway bar do... Since I have installed TEIN coilovers I had troubles with rear a bit. Every single unevenness of road or hole I drove over made big noise at rear. Not that kind of clacking noise (like from bad upper mounts) but one big loud bang. Now it's gone. Moreover I have feeling ride is more smooth... I mean... even with TEINs I had feeling car is... "clattering" (I hope it's right word for what I want to say) on bad surface before. Not now. No more clattering anymore smile.gif
post Sep 9, 2008 - 12:58 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
the difference is like night/day isn't it.
must feel like the car is on rails! but if this is the case, you're not going fast enough wink.gif
drive safely!
post Sep 13, 2008 - 11:09 PM
HaRv3sTeR
Joined Nov 22, '03
From Tracadie-Sheila, NB (Canada)
are those new endlink OEM? if not, what company?
post Sep 13, 2008 - 11:14 PM
QUOTE (HaRv3sTeR @ Sep 14, 2008 - 12:09 AM) *
they're made for the st185 by "twosrus"
here's a link to a discussion and pics
http://www.6gc.net/forums/index.php?showtopic=40246
post Sep 14, 2008 - 10:31 AM
did you have to adjust the end links. to how much
post Sep 14, 2008 - 1:58 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
they are set at the same length as the oem ones
エキサイティングカーレーシングチーム!
post Sep 15, 2008 - 12:44 AM
netrata
Joined Feb 16, '06
From Maui, Hawaii
Nice Job Malpaso biggrin.gif I got the same setup as yours, twosrus endlinks and suspension technique sway bars (version 1 but it doesn't rub)
This post has been edited by netrata: Sep 15, 2008 - 12:45 AM
post Sep 16, 2008 - 10:29 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
nice! i can't wait till i order mine. But thats not till winters over.... But i'll be adding new struts and lowering springs to the mix smile.gif
2nd Gen 3s-gte.... It lives!
97celiman
post Nov 11, 2010 - 4:45 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
Can anybody to a side to side Comparison picture of a Stock GT-4 SuperStrut Front Sway Bar End link vs SS-II/GT/ST McPherson Front Sway Bar End link. I'm curious to know whether the two's r us end link will work up front even though some said it doesn't.
post Nov 12, 2010 - 12:43 AM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
how is the highway sound with that exhaust system? and what size are you useing?
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
post Nov 12, 2010 - 6:22 AM
malpaso
Joined Feb 3, '06
QUOTE (BonzaiCelica @ Nov 11, 2010 - 10:45 PM) *
Not a chance for front... I tried to use two's r us end links for my GT-four now and front is too short to fit. they are like 2-3x longer for front on GT-four. That black upper one is OEM GT-four rear and lowest one OEM GT-four front.
post Nov 12, 2010 - 12:31 PM
QUOTE (4-eyed-freek @ Nov 12, 2010 - 12:43 AM) *
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Nov 12, 2010 - 1:09 PM
4-eyed-freek
Joined Apr 17, '10
i had the same thing on my 5s and man.. it sounded like a huge bumble bee was in my trunk! so i went and put a res. on it and made it more realistic. but than angain i dont have the same engine... i dont think.
post Nov 12, 2010 - 8:59 PM
BonzaiCelica
Joined Apr 24, '08
then what are those. Those sway bar links that are the same exact size as the gt-four stock end links??? The two longer silver end links that look aftermarket??
This post has been edited by BonzaiCelica: Nov 12, 2010 - 9:00 PM
post Nov 13, 2010 - 3:43 AM
TRDGT4
Joined Mar 3, '08
From New Zealand
QUOTE (malpaso @ Nov 12, 2010 - 7:22 AM) *
^^ so these you made up yourself??
_______________May COTM 2011_______________
Lo-Fi Version Time is now: August 29th, 2026 - 6:43 AM
