Nov 21, 2008 - 12:39 PM
Ok i've done this in the past as a modification when i had my car, I want to know what, how and method you guys have used to do yours
this requires specific information that i want to see what battery (brand, size) where did you put it. what wires for ground and positive (gauge) what connections did you use where did you connect your grounds where did you run your wires. this is all i want posted, there need not be excess noise in the thread. Just for some add in information stock battery spec: Group 35/ CCA 360 This post has been edited by playr158: Nov 21, 2008 - 12:44 PM |
Nov 21, 2008 - 12:46 PM
Enthusiast ![]() ![]() Joined Oct 23, '08 Currently Offline Reputation: 24 (100%) |
There is a sticky about this in the electrical section HERE It has som pretty good info that might help
Nov 21, 2008 - 12:49 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Stock Battery Group 35/ CCA 360
I used a battery holder box that comes with the top and a strap to hold the battery down in the trunk. I have all the hatch plastics out so put the battery near the right wheel well where the factory jack goes. I used self tapping screws to hold down the battery box. I then used a 4 gauge jumper cables running all the way to the back. Ran it through my wiring harness hole and under my door sills to the hatch. I just utilized my old ground and positive from the engine bay. I just connected the jumper cables to the positive and one to the negative and ran it back and hooked the other ends of the jumper to the battry as if it were in the engine bay. For some reason it takes longer to turn the car over then before. I don't know whats causing the lack of power. I was thinking its because the battery is all the way in the back, but as long as my car starts thats all that matters. -------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Nov 21, 2008 - 2:50 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
optima yellowtop(800CCA?) in rear/optima redtop(1000CCA) in front
left hatch between shock mount, rear, and my sub box/stock location 4 gauge for ground, 2 gauge for positive(to dist block, 4ga to front batt.)/2gauge for ground, 4gauge to rear battery, 8gauge to alt, 4gauge to starter rear has cheap gold from autozone/Front battery has high quality gold terminals from autozone ground connected to strut mount/grounded to: engine, tranny, strut mount, and stock location near headlight ran wire along factory wiring on drivers side, then followed airbag wiring through wheel well, then into engine bay/not much to running wires in the front btw its rear battery info/front battery info -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Nov 21, 2008 - 4:30 PM
this is how we do ours, dan.
![]() ![]() ![]() dustin and steff have pretty much the same, just smaller terminals. -------------------- Former Team 5SFTE pro member ;)
Dec 25, 2008 - 9:51 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 14, '06 From MN, USA Currently Offline Reputation: 2 (100%) |
Bump add more info if you've done the batt relo.
Dec 26, 2008 - 11:09 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
The pictures Manny posted are of one of Shannon's cars, I don't remember which, but mine and Dustin's are pretty much the same so here's some more info
Optima Red Top Group 35/720cca In the trunk towards the left rear wheel well area, cut holes in plastics with rubber grommets to make it look neat (like Manny's picture above) ![]() Optima battery tray--search it on ebay ![]() Rockford Fosgate battery terminals (up to 4ga cables only with just one additional input for accessories) 4ga power cable, Shannon has 2ga cable but 4ga is smaller and is just fine plus easier to run through the car Route the power cable behind all the plastics, under the door sill, through the firewall/steering boot to the engine bay. Ring terminals from Autozone, attach one to the end of the 4ga power cable that was run to the front of the car and remove the stock positive battery terminal end and put the other one on that end, then bolt them together for easy disconnecting from the harness. ![]() Ground cable goes directly from the battery to the chassis. Dustin's ground cable goes from the battery to the chassis between the tail lights and from the stock negative terminal end in the engine bay to the transmission ground point using something like this, with one end cut off and stripped to go into the terminal (only black because it's negative). ![]() I have the same setup but with an additional ground cable from the negative terminal run alongside my power cable to the engine bay and bolted to the stock location on the transmission, then from that ground point to the stock chassis ground point in the front. This post has been edited by hurley97: Dec 26, 2008 - 11:02 PM -------------------- |
Dec 26, 2008 - 7:49 PM
Enthusiast ![]() Joined Jun 3, '08 From Ireland Currently Offline Reputation: 0 (0%) |
I want to do this too. Optima batteries seem pretty good
Edited my post with more detail.
| Lo-Fi Version | Time is now: August 19th, 2026 - 6:23 PM |
